what is the bennefit of firefox
firefox is the best browser
1. Flash Support You might already know the fact that Abode Flash is not officially available for Android Jelly Bean any more due to security reasons and Google has removed the support from Chrome for Android as well. Even if you are working on Android Ice Cream Sandwich and Adobe Flash is installed on the device, you will not be able to view flash content on Chrome.
On the other hand, currently Firefox provides a stable support for Flash and if Flash app is installed on the device, you can play Flash content without any glitches. Dolphin HD also provides native support for Flash and is worth checking out. 2. Add-ons Support
Both Chrome and Firefox provide support for extensions and add-ons when it comes to desktop browsers but only Firefox continues the legacy to Android. Firefox for Android supports add-ons using which you can enable some additional features on specific websites. For example, there are add-ons using which you can download flash videos from websites, block ads and do so much more.
The add-ons for Android browser differ from those that are used by the desktop version of the browser and thus the latter’s versions cannot be used on the former. However, many add-ons have already been ported and developers are working on the rest.
3. Reading View As much as I love writing articles, I love to read them as well. I usually use my Android tablet to read online articles and Firefox makes sure I have a wonderful experience doing that. Reading mode in Firefox is an amazing feature that strips it off all the unnecessary clutter on the page and gives you just what you should be concentrating on. If a page has enough content and the reading mode is supported for it, you will see a book icon on the right corner of the URL bar. Simply tap on the icon to activate Reading Mode for that page.
Firefox also supports Reading List and you can add a page to it using the option in its menu.
4. Supports Larger Range of Devices While Chrome is only supported for Ice Cream Sandwich devices and above, Firefox for Android supports Gingerbread devices as well. As both my devices are upgraded to Ice Cream Sandwich, the matter doesn’t concern me. But as a large percentage of Android users are still running theirs on Gingerbread, Firefox is the most optimal choice in browsers that’s available for them.
